Send email notification using pipeline blocks
I put a logger after this line users = system.db.runNamedQuery("getUserStatus")
I can't see logger message.
SQL request is not working. This is a mistakle for me because it is working on console
Console and pipeline are not in the same scope. You'll need to use the gateway scope syntax, where you pass the project name too.
I'm really surprised you don't have errors in the logs because of this... Or maybe you looked over them ?
j'ai testé ligne par ligne et j'ai constanté qu'il faut ajouter le nom du projet sur la requette.
system.db.runNamedQuery("TurbineV520","getUserStatus")
