Sql pareto for column values per row help request
Where’d the “u” comes from in the output?
You made that scripting method easy to understand. Thanks @JordanCClark
Company uses 8.1.0 Ignition, no script scheduler. So I tend to use prepared queries.
Was able to finish a pareto chart this afternoon by making a fault table, transaction groups, and a query like the one Phil and a few of you helped me with last year:
HERE
Not the same as the wide table.
Wanted to finish today, and didn’t know how else.
Thanks for helping me.
I checked the links. That example with the unpivot didn’t make sense to me.
Then when I clicked the link recommended off from it with the phone types, that was confusing enough that I switched gears to make the tall table and query.
That just says it's unicode. if you print the actual element of the list the 'u' won't show.
Ah, I think I have to make a wide table work for scrap tomorrow.
Looks like one of the techniques is making a subquery that converts the wide table to a tall table by combining the wide columns into one column. I think it was confusing to me because I didn’t know how I would get the t_stamp to work with it, but now I have an idea.
I think I can do that, and concat some other columns as needed.
These stack exchange posts seem to stretch back 10 years and still don’t have good solutions.
I don’t know what the solution is in sql, but it is not trivial for sure.
My idea with concat did not work.
I'm thinking the company is hamstringing itself if it's not using the tools available to it.
I am sure they are trading reliability of third party dashboards for all the features and big fixes.
I don’t like to mention it, but it seems like each post I must mention once or some ideas that work on more updated versions come up.
The script way works in the console for the testing.
To make it work for my application though:
I need to
  1. make table on a perspective page
  2. bind the data:
data =[]
dataIN=system.dataset.toPyDataSet(system.db.runNamedQuery(namedQuery, parameters))
or since it is in a bindings
  1. query binding to my named query filtered for machine and time range
  2. then use the script transform
  3. in the script transform I use
data =[]
dataIN=system.dataset.toPyDataSet(value)
  1. include the header filtering
  2. perform the reversed, sorted, zip which gets data into rows with columns sorted by the max
return pareto
Pareto in the script is a pydataset?
pareto variable became a pydataset because filteredheaders became a pydataset in the list comprehension getting the column names rom dataIn
a pydataset can be returned as the data for a table in perspective if I understand correctly
I plan to try this in the morning. I don’t think I can break it, but my brain is jello.
Tried for a long time to find a way that a wide table can be converted to tall table
functionally
for row in dataIn:
	data = [row[colName] for colName in filteredHeaders]
	#Sorting a zip sorts all lists by the first one.
	pareto = [[x, y] for y, x in reversed(sorted(zip(data, filteredHeaders)))][:5]
	print row['t_stamp'], pareto
dataIn is a pydataset because set it as one
filteredheaders is a pydataset because it is comprised of dataIn
data is a pydataset because it is comprised of filteredheaders
pareto is a pydataset
so I am not sure I understand
I have 5 pages of the manual open, but am not figuring it out.
I think a few examples are just shy of filling in the gaps for me.
I understand SQL much better, but this seems like something that can’t be done in SQL.
Or if it can be, it requires a query of the information schema to get the column names and manipulate them, which I am pretty sure I can’t do because of permissions.
What I gave was a proof of concept. What do you envision for your table layout?
I thought I would get the proof of concept to work in a table on a view.
Then I would use what I had learned to make the actual thing I would display.
My vision is a table of scrap reasons per line sorted by the amount of scrap
(line ) ( scrap reason) (# scrapped) (percent of total scrapped) ( total scrapped)
[ rows of  reasons for scrap that are sorted by the amount scrapped]
I did this for my faults, but I did it with a query.
I had the transaction group setup perfect for it though. One column was the code and the transaction triggered when that code changed.
I am not a fan of working with counters in a plc to setup a table in Ignition.
I prefer to get increments from the plc, make transaction groups capture the increments, then query those to make my counts. After this though, maybe counters will be easier.
wish I got it to work in a query, I want to do some graphs with the data too
I'm not qualified to help with sql, but...
sorted can take a reverse parameter, so you could do this instead:
pareto = [[x, y] for y, x in sorted(zip(data, filteredHeaders), reverse=True)][:5]
Not having several parentheses next to each other makes me happier.
ah
we use reverse for descending
I got this when I tried to print
print dataIN
<PyDataset rows:1 cols:30>
or I get each value on a new line with this
for row in range(dataIN.getRowCount()):
	for col in range(dataIN.getColumnCount()):
		print dataIN.getValueAt(row,col)
trying to get the header next to it, print someheaderthing+dataIN.getValueAt(row,col)
oh I see, you zipped the header with the data to get them in the same row,col
The advantage of a pyDataset is you don't have to go to all of that trouble.
for row in dataIN:
    for value in row:
        print value
I really hope they make basic datasets iterable someday
Here's a function to help with that.
error: line 14
list object has no attribute getRowCount
lol nooooooo
I defined namedQuery, reasonHeaders, params, and dataIn
6   dataIn=system.dataset.toPyDataSet(system.db.runNamedQuery(namedQuery,params))
7   print datatIn
11  for row in dataIn:
12        filtered headers = [colName for colName in dataIn.getColumnName() if colName in reasonHeaders]
14     for row in range(filteredHeaders.getRowCount()):
15	     for col in range(filteredHeaders.getColumnCount()):
16		   print filteredHeaders.getValueAt(row,col)
Well, your header is not a dataset, you can’t call dataset methods on it
And, you only need to get the filtered headers once.
print datatIn
filteredHeaders = [colName for colName in dataIn.getColumnNames() if colName in reasonHeaders]
for row in dataIn:
	for col in filteredHeaders:
		print col, ' : ', row[col]
so the function you posted to help, that lets you view a dataset from script console
I thought I already could do that with the two ways in LRose’s post?
OHH your post adds the structure, so you can visualize it, got it
oh so I just print the list to check it
dataIn=system.dataset.toPyDataSet(value)
reasonHeaders = ['thisReason', 'thatReason', 'nReason']
for row in dataIn:
	data=[row[colName] for colName in reasonHeaders]
	pareto = [[x, y] for y, x in reversed(sorted(zip(data, reasonHeaders)))]
return pareto
omg it is a alive,
on the table, I set field to column_1 and the next one to colomn_2
then I set the headers to reason and quantity
Now I just have to go back and edit the dates into query and some summing
seems to be handling none type well so far, but if I add summing, I probably need isnull
I have it looking great, except when the values are 0 for reason, they are listed in reverse alphabetical order haha
nobody has complained yet
I have to add net and defects to the table, then also line and a percentage of defects per net
However, I am not getting an error, yet it is not working.
time is going too long on the script execute, says interrupt on the button
I defined reasonHeaders and suffixHeaders.
reasonHeaders=[‘thisReason’,…‘nReason’]
suffixHeaders=[‘thisNet’,…‘nCalculation’]
for row in dataIn:
#print pareto
for row in dataIn:
	data2=[row[colName] for colName in suffixHeaders]
	testThis =[[x,y] for y, x in zip(data2,suffixHeaders)]
print testThis
for row in pareto:
	for col in pareto:
		pareto.append(testThis)
print '-----'
print pareto
I thought if I got them both in lists, I could do something like:
for column append
keeps timing out, I am reviewing append function
I am not sure how the append function handles appending a list of lists to another lists of lists, but I’m not certain that’s really what you’re looking for anyway.
Also, I don’t believe there will be any data in testThis, unless there are actually column names in dataIN that actually match the suffixHeaders.
How are you defining “net”, “defects”, “line”, and “percentage of defects per net”?
