SQL Query Tag Issue
Check to make sure you have this line at the beginning of the stored procedure:
SET NOCOUNT ON;
Otherwise it returns two datasets, the first being a count of records affected, the second being your actual data. Here’s a sp i just created to test:
[code]CREATE PROCEDURE QueryTagResult
@x int
,@y int
AS
BEGIN
SET NOCOUNT ON;
select @x + @y as 'value'
END
GO[/code]
And for my SQL Query Tag, I have this as my statement:
execute QueryTagResult 2,3
Make sure the Query Type is set to “Select”
Hope that helps!
