I tried editing the previous post but did not change so posting it here again based on the suggestion.
Thank you
"type": "ia.chart.xy",
"version": 0,
"props": {
"background": {
"render": "color",
"color": "#FFFFFF"
"xAxes": [
"name": "x",
"label": {
"enabled": true,
"text": "dim desc",
"color": "#000000"
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "category",
"category": {
"break": {
"enabled": false,
"startCategory": "",
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"skipEmptyPeriods": false
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy-MM-dd kk:mm:ss",
"format": "M/d"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"logarithmic": false,
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###.##"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 90,
"verticalCenter": "middle",
"horizontalCenter": "middle"
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": 60,
"position": 0.5
"font": {
"size": 9,
"weight": 500
"yAxes": [
"name": "y_v",
"label": {
"enabled": true,
"text": "value",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "value",
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"format": "M/d/yyyy HH:mm:ss"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 0,
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": null,
"position": 0.5
"font": {
"size": "",
"weight": 500
"appearance": {
"font": {
"size": "",
"weight": 500
"grid": {
"color": "",
"dashArray": "4,4",
"opacity": 1,
"position": 0.5
"inside": false,
"labels": {
"color": "",
"horizontalCenter": "middle",
"opacity": 1,
"rotation": 0,
"opposite": true
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05,
"startCategory": ""
"date": {
"baseInterval": {
"count": 1,
"enabled": false,
"skipEmptyPeriods": false,
"timeUnit": "hour"
"break": {
"enabled": false,
"endDate": "",
"size": 0.05,
"startDate": ""
"format": "M/d/yyyy",
"range": {
"max": "",
"min": "",
"useStrict": false
"inversed": false,
"label": {
"color": "",
"enabled": true,
"text": "t_minus"
"name": "y_m",
"render": "value",
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"text": ""
"value": {
"break": {
"enabled": false,
"endValue": 100,
"size": 0.05,
"startValue": 0
"format": "#,###.##",
"range": {
"max": "",
"min": "",
"useStrict": false
"visible": true
"series": [
"name": "value",
"label": {
"text": "value"
"visible": true,
"hiddenInLegend": false,
"defaultState": {
"visible": true
"data": {
"source": "example",
"x": "dim_desc",
"y": "value"
"xAxis": "x",
"yAxis": "y_v",
"zIndex": 0,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{valueY}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "column",
"candlestick": {
"open": {
"x": "",
"y": ""
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"deriveFieldsFromData": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": true,
"width": null,
"height": null,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"line": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": false,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"stepLine": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"candlestick": {
"appearance": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": "",
"min": ""
"stacked": false,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"open": {
"x": "",
"y": ""
"column": {
"appearance": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"fill": {
"color": "#EC2F2F",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": "",
"min": ""
"height": null,
"stacked": true,
"stroke": {
"color": "#C02323",
"opacity": 1,
"width": 1
"width": null
"open": {
"x": "",
"y": ""
"data": {
"x": "dim_desc",
"y": "t_minus"
"defaultState": {
"visible": true
"label": {
"text": "minus"
"line": {
"appearance": {
"bullets": [
"fill": {
"color": "",
"opacity": ""
"rotation": "",
"stroke": {
"color": "",
"opacity": "",
"width": ""
"enabled": false,
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": 100,
"min": 2
"height": 10,
"label": {
"position": {
"dx": 0,
"dy": 0
"text": "{value}"
"render": "circle",
"rotation": 0,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"width": 10
"connect": true,
"fill": {
"color": "",
"opacity": 0
"minDistance": 0.5,
"stroke": {
"color": "",
"dashArray": "",
"opacity": 1,
"width": 3
"tensionX": 1,
"tensionY": 1
"open": {
"x": "",
"y": ""
"name": "minus",
"render": "column",
"stepLine": {
"appearance": {
"bullets": [
"fill": {
"color": "",
"opacity": ""
"rotation": "",
"stroke": {
"color": "",
"opacity": "",
"width": ""
"enabled": true,
"fill": {
"color": "",
"opacity": 1
"heatRules": {
"dataField": "",
"enabled": false,
"max": 100,
"min": 2
"height": 10,
"label": {
"position": {
"dx": 0,
"dy": 0
"text": "{value}"
"render": "circle",
"rotation": 0,
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"width": 10
"connect": true,
"fill": {
"color": "",
"opacity": 0
"minDistance": 0.5,
"stroke": {
"color": "",
"dashArray": "",
"opacity": 1,
"width": 3
"tensionX": 1,
"tensionY": 1
"open": {
"x": "",
"y": ""
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"visible": true,
"xAxis": "x",
"yAxis": "y_m",
"zIndex": 0
"dataSources": {
"example": {
"ds",
192,
1756110119121
"$columns": [
"name": "dim_desc",
"data": [
"Diameter_.4063_Cyl_1",
"Diameter_.4063_Cyl_2",
"Diameter_.287_Under-cut_1",
"Diameter_.287_Under-cut_2",
".001_Straightness1"
"type": "String"
"name": "value",
"data": [
0.4054267704486847,
0.4048752784729004,
0.2851211726665497,
0.285286545753479,
0.0005077047972008586
"type": "Double"
"name": "t_plus",
"data": [
0.4070000082720071,
0.4070000082720071,
0.29200000036507845,
0.0010000000474974513
"type": "Double"
"name": "t_minus",
"data": [
0.405600008321926,
0.405600008321926,
0.28200000058859587,
0
"type": "Double"
"meta": {
"name": "XYChart_1"
"position": {
"x": 648,
"y": 579,
"height": 913,
"width": 857
"custom": {}
