Great catch Frank! I gave it a quick test and it seems to work as expected. Here are the updated functions:
def getTagConfigStr(tagPath):
return system.tag.exportTags(tagPaths = [tagPath])
def getTagConfigObj(tagPath):
return system.util.jsonDecode(getTagConfigStr(tagPath))
Thanks for this. I never would've guessed removing the path property would be CRITICAL for my use-case: removing overridden .enabled alarm properties.
If I don't remove it, UDT-inherited alarm .enable properties are overridden to False, though my config purposefully excludes that property (so that they will revert to Inherited)...
I'm glad my hours of painful development were able to save some for you! It makes sense that the path tag property should be read-only, but the fact that you can write to it is kind of obnoxious; the strange side-effects caused by writing to it even moreso.
