System.tag.exists in expression error
Or isAvailable() from Paul's Ignition Extensions module, which checks if the tag is both not disabled and exists, because those are the only two states in which you would want to hide something using, otherwise you would be masking a genuine issue. (to test for these two qualities without isAvailable is a horrible monster of an expression)
Still hoping that this makes it into the product!!!!
