System user functions
It works now!
It seem .setRoles does not work.
.addRole does.
I had tried importing java string, and then making my string for the role into a java string. Well it sort of worked, but then I got an error that some kind of python object could not be converted.
So then I went with addRole.
Thanks so much for all the help.
# List of emails to check against
email_list = ["email1@example.com", "email2@example.com", "email3@example.com"]
# Retrieve all users
users = system.user.getUsers('default')
# Loop through each user
for user in users:
    # Get contact info for the user
    contacts = user.getContactInfo()
    # Check if any contact is an email in the email_list
    for contact in contacts:
        if contact.contactType == "email" and contact.value in email_list:
            # Get the user's current roles
            current_roles = user.getRoles()
            # Append the role if not already present
            if "roleThatExists" not in current_roles:
                print user
                user.addRole("roleThatExists")
                response =system.user.editUser("default", user)
                print response.getErrors()
