(I’m not an expert in either the old or the new tag system)
You will hopefully be able to switch to the new ManagedTagProvider concept; it’s a simpler scaffolding that helps with setting up the basic idea of “Java code that provides Ignition tags”.
I’d start from the SDK example and work from there:
As a general rule: Anything under the sqltags package is deprecated or outright removed.
