Three Javascript injection
If you miniefied a whole lib, you should definitly put it into either a module,
or if you are not familiar enough with JAVA you should put the mini.js script into injectables.
Check out this post, here i copied a mini lib to injectable/head.txt. and call its functions in a markdown
That said a module for three.js is probably something other people are interested in too.
