Transaction groups delete records older than
query = "DELETE from test.statustest WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 11 DAY)"
system.db.runQuery(query, 'dbConnection')
Some references:
https://docs.inductiveautomation.com/display/DOC80/Gateway+Event+Scripts
https://docs.inductiveautomation.com/display/DOC80/system.db.runQuery
these references you send me for self-development?
If i have MySQL80 database, what you can see on pictures. then i should replace dbConnection on MySQL80?
please, can you see previous my message
Give a man a fish, and you feed him for a day; show him how to catch fish, and you feed him for a lifetime. :slight_smile:
That is correct. See? You're already learning to fish.
thanks, but it doesn t work. I don t know why. I checked all variant which I can think up.
Maybe firstly i should call to this DB an then use command for delete some rows?
How are you trying to use this?
query = “DELETE Select * FROM hourlystatistic WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 2 HOUR)”
system.db.run(query, ‘MySQL80’)
system.db.run(“DELETE Select * FROM hourlystatistic WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 2 HOUR)”, ‘MySQL80’)
try system.db.runQuery()
query = "DELETE Select * FROM hourlystatistic WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 2 HOUR)"
system.db.runQuery(query, 'MySQL80')
this code not work…
in this window, this code is working
Try it in the Script Console. If it displays an error, what does it say?image
Java Traceback:
File "", line 2, in
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runQuery(AbstractDBUtilities.java:333)
java.lang.Exception: java.lang.Exception: Error executing system.db.runQuery(DELETE Select * FROM hourlystatistic WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 90 Minute), MySQL80, )
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:524)
at org.python.core.PyObject.__call__(PyObject.java:497)
at org.python.core.PyObject.__call__(PyObject.java:501)
at org.python.pycode._pyx1280.f$0(<input>:2)
at org.python.pycode._pyx1280.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at org.python.core.Py.exec(Py.java:1658)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:131)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:605)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:593)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runQuery(DELETE Select * FROM hourlystatistic WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 90 Minute), MySQL80, )
... 26 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Can not issue data manipulation statements with executeQuery().
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runLimitQuery(GatewayInterface.java:860)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runQuery(GatewayInterface.java:826)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runQuery(ClientDBUtilities.java:325)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runQuery(AbstractDBUtilities.java:329)
... 24 more
Caused by: java.sql.SQLException: Can not issue data manipulation statements with executeQuery().
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:129)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:89)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:63)
at com.mysql.cj.jdbc.StatementImpl.checkForDml(StatementImpl.java:367)
at com.mysql.cj.jdbc.StatementImpl.executeQuery(StatementImpl.java:1135)
at org.apache.commons.dbcp2.DelegatingStatement.executeQuery(DelegatingStatement.java:310)
at com.inductiveautomation.ignition.gateway.datasource.DelegatingStatement.executeQuery(DelegatingStatement.java:64)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRStatement.executeQuery(SRConnectionWrapper.java:820)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.RunQuery.run(RunQuery.java:80)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:68)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:414)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
at java.lang.Thread.run(null)
File "", line 2, in
Keyboard Interrupt
qw
Sorry just noticed the query text. Get rid of the Select * after the DELETE.
query = "DELETE FROM hourlystatistic WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 2 HOUR)"
Somewhere in there should be lines starting with ‘Caused by:’. That is where the vital clues will be.
Java Traceback:
File "", line 2, in
java.lang.Exception: java.lang.Exception: Error executing system.db.runQuery(DELETE FROM hourlystatistic WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 90 Minute), MySQL80, )
at org.python.pycode._pyx1299.f$0(<input>:2)
at org.python.pycode._pyx1299.call_function(<input>)
Caused by: java.lang.Exception: Error executing system.db.runQuery(DELETE FROM hourlystatistic WHERE t_stamp<=DATE_SUB(NOW(), INTERVAL 90 Minute), MySQL80, )
... 26 more
... 24 more
File "", line 2, in
Keyboard Interrupt
Are you sure it worked in the Database Query Browser? the pic you posted shows entire rows, when it should be displaying the number of rows it deleted.
Is the designer set for read/write?
