200 records to SQL Server is NOT a heavy load by any means.
I would script this and either do a gateway tag change script to trigger it, or schedule it with the API call and then use the bulk insert code from this thread utilizing the prepInsertQMarks specifically.
I gather around 4000± tag values every 15 minutes and write the values to rows in a database that are 4 columns wide, the entire thing is done in around 8 seconds, mind you this is also gathering those data points from 15 different gateways.
