UDT Parameter math is not evaluating correctly
2/16 as an int should be 0, so I should end up with ns=1;s=[PL_STACKER]PL_Stacker.Alarm[0].2
which is the intention.
But what you’re saying is that the parameter division is not doing integer division?
But if that is the case then why doesn’t the expression testing tags that I created evaluate either?
