Hey all,
If you are trying to debug certificate path issues on Windows within the launchers you have to do two things to see the evaluation:
- next to the launcher's executable file (in this case
designerlauncher.execreate a file with the namedesignerlauncher.l4j.iniand add a single line with the contents of-Djava.security.debug=certpathand save it. - run the exe from the command line and redirect the output like so:
"C:\Users\%USERNAME%\AppData\Roaming\Inductive Automation\Designer Launcher\designerlauncher.exe" 2> "C:\Users\%USERNAME%\Desktop\stderr.log" 1> "C:\Users\%USERNAME%\Desktop\stdout.log"
(Update the paths as required)
once you attempt to connect over https you should see the stderr.log file populated with the output from the jsse debugging.
I would recommend cleaning out your launcher configuration of other saved apps and altering the launchers logging level to something like trace to try to get a complete picture of what is happening.
EDIT: updated to designer launcher instead of the Vision Client Launcher.
