It worked for me in following way.
I deleted .Ignition file from \Users folder and then again tried to add designer and launch. It worked like before.
I am getting this error and yes my ignition is installed on redhat linux and I am opening it in windows PC. my redhat has 8.1.23 and my PC has 8.3.0 installed. I am able to to open in my other PC that has 8.1.48 installed but I want to open it in 8.3.0 but do not want to upgrade it.
See the advice at Launchers and Workstation | Ignition User Manual, you'll have to edit one of the launcher files.
Thank you very much. I changed to LENIENT and it worked. Seems 8.3.0 is considering 8.1.23 as legacy and it’s jar file is unsigned which was causing fault. All good now.
I set up a Linux VM for testing 8.3 things before we attempt a migration. Problem for me is that I installed with sudo and the .ignition folder in my home was owned by root. I changed permission to my local user and the error went away.
I had similar issue. After pressing the Date &Time Settings - > Sync Now, my issue is resolved.
Modifying the signature.verification.strength value worked for me. Thanks!
