Not sure technically in this instance, but setting visibility without it will simply hide the tab and not shift the others and take its place. It acts more like setting visible on a component in a flex, and adding position: absolute acts like display
Its the way the positioning works. Setting it to absolute will set it to 0,0 on a different layer basically. If you set two things to absolute and give them the same top and left they will be overlayed. Same thing is happening there.
I guess it also pulls it out of the flex that the other tabs are in which is why they're able to collapse the space
I wonder if you could replace
position: absolute
visibility: hidden
with
display: none
and get the same thing.
Or possibly visibility: collapse
That didn't work, I did try that, still needed absolute
You can use style.position: absolute to take a component out of a flex container and position it anywhere within the flex. For example to move it to the bottom, offset by 2px from the bot left and set its width to the width of the containing flex minus 4px to give a 2px offset from the flex side bounds:
style.
position: absolute
left: 2px
bottom: 2px
width: calc(100% - 4px)
height: 4px
In some cases this is preferable to using a coord container. For example I use this to put icons (no priv, confirmation required, etc - these themselves are container within a flex) in the top right of my button template with exact size and pixel offsets from the bounds, regardless of the size the button is embedded as. You can't* do this in a coord container (*that I know of).
However, sometimes the positioned component will appear relative to the wrong outer container, eg in the top right of the entire page. In this case, add this into the containing flex container:
style.position: relative
I'm sure someone will pipe in with the reasons why this is needed and under what circumstances (i haven't found the time to look into it)
Don't have anything clever to add but I just wanted to say this is a goldmine, thank you all for sharing! The composable style systems and repeating roller SVGs I thought we're especially awesome ![]()
How can one create this style, so it can applied to components in the designer.
Thank you
Copy and paste the CSS into the Advanced Stylesheet in your project and save it.
Then on the component, set the props.style.classes to pulse-shadow
If you don't see an advanced style sheet you need to add it to your project. You do this by right clicking on the "Styles" section and selecting the option for the advanced style sheet. I forget exactly what it says but I typically enable that on all of my projects these days.
That was definitely the intention of it!
I'm going down the same journey.. have calculated px on my primary window, and wrote those values to session.custom so i can ref them from wherever. Then moved to em. Now playing with rem, calculating out a rem value in :root{}. What's caused you to go back to the clamp?
cough I've gone back to rem..
But defined media queries in the stylesheet to change the root fontsize based on resolution..
fwiw, this is what I've been testing with, and it seems to be holding up ok...
/* Default root font size (applies to all screen sizes unless overridden) */
html {
font-size: 16px; /* Base size: 1rem = 16px */
/* For small screens (e.g., mobile phones). Note this is larger than the tablet size otherwise it's too small on mobile*/
@media screen and (max-width: 480px) {
html {
font-size: 14px; /* On small screens: 1rem = 14px */
/* For medium screens (e.g., tablets) */
@media screen and (min-width: 481px) and (max-width: 1499px) {
html {
font-size: 12px; /* On medium screens: 1rem = 15px */
/* For large screens */
@media screen and (min-width: 1500px) {
html {
font-size: 18px; /* On large screens: 1rem = 18px */
Nice. I haven't played with the media queries. I'm currently giving this a try. Not sure I like starting at a 5px base. I'm probably going to move it to 10 or 16. 10 makes for easy math to get to my standard font sizes at our common resolutions. The little bit of math does a pretty good job of dialing font size respective to resolution so it stays pretty well scaled to all the other stuff.
Biggest thing I've noted so far, I've had to adjust the sliders and checkbox styles to bump their size due to my 5px rem. Moving to 16px I think would allow me to not have to do that.
:root {
--base-font-size: 5;
html {
font-size: calc((1vw / 19.2) * var(--base-font-size));
16px is the default rem size if you don't set it yourself, which is why I started there ![]()
Who am I kidding, I didn't write it, it was Claude who wrote it for me after I was cursing at my calc font sizes not behaving, I just tweaked it a smidge ![]()
Yeah, that's why I'll probably head back to 16 as my start point. Make designer more realistic that way as well (really wish Designer handled CSS better).
Gemini has been my friend..
I use Claude.ai, it's far better at code (thanks @chaoliang )
So does the calc and clamp not work any longer?
I am trying to use some styles, that I created a while back, in a new project, but I don't see any effect at all in the browser, as far as font sizing goes. In the Designer, I can make it super small, and it's normal in the browser.
