Using Expression Structures in a flex repeater
Normally I would make a binding on the instances parameter in the flex repeater and get the list of parameters you will need to pass and generate an array of instances with the contained parameters using a script transform in this binding, then you will have a flex repeater with unique instances.
One example of this type of binding is:
