Using the information of a Power Table in a label that is in another window
Well then you do the same thing, except instead of putting the data into the table, you put it into a tag with system.tag.writeBlocking
But if you have a working solution, maybe just keep it.
I think if I put it in a tag also I can show data on a label without pressing a button. So, I'm also going to try your suggestion.
Yes you can bind your label's text to the tag. Use an expression binding that uses lookup.
