yes but what if you call your script in the transform script and use an structured expression binding
I’m not sure why, but for whatever reason, even if you build the structure in the designer, you do indeed end up getting class com.inductiveautomation.perspective.comonImmutableQualifiedValue ![]()
So system.util.jsonDecode() doesn’t work. Anyway, this does work:
shiftPat = []
for v in value:
shifPat.append({k:v.value[k] for k in v.value.keys()})
you should use an expression struct and bind on these params
{session.custom.datePicker},
{view.params.config.shiftPattern}
That makes sense - otherwise the binding wouldn’t update on date change, etc.
I’ll have to look at it later.
@Transistor thanks for starting the thread. I was having the same problem.
I was also calling scripts only from Expression transforms.
Indeed!
When using Expression transforms, the type passed is ImmutableQualifiedValue. I was having a hard time getting around it, but Script transform did the trick.
Probably you already solved it. In case you haven't, your first expression binding would be bind to a date change instead of a dummy true
