@nminchin mentioned cycling a client tag using a client timer script. For the way I mentioned you don’t need the client timer script at all. When you set up your client tag, you go to the Expression/SQL section of the tag and set it to expression and insert the expression I showed. That expression does a 1 second pulse. You can change it based on how fast or slow you want the pulse to be.
