Web Browser Module "Crash" on Vision Client startup (Linux)
Any additional error information is going to be on the machine running the Vision Client.
Check ~/.ignition/clientlauncher-data for a log file and upload it here if you can. Inside that log file there's going to be a long message where it logs the command it actually used to launch a client. Copying that command into a terminal and running it there will allow you to get the actual log output from launching a client.
