WebDev Questions
Thanks I will look into it. I had done it in JAVA version using sdk, but i am trying script version.
Since which version of Ignition is the webDev module supported in Ignition? I observe that its available in version 7.7.1 and above but not in 7.7.0! and 7.8 (but in 7.8.1 its supported).. Just want to ensure that my modules work on a as many versions of Ignition as possible!
Where to find webdev module for Ignition 8? I was using a build version of Ignition 8. After downloading the latest trial version , installer gave a warning that webdev will have to be manually installed. However I am unable to locate the link for webdev download on Ignition 8. (for archived versions of Ignition there is a link for ignition modules Archived Ignition Releases | Inductive Automation . But where to download the addons for version 8 from?
Webdev is under ‘Device Connectivity’ (misleadingly, I let marketing know about it) on the downloads page: https://inductiveautomation.com/downloads/ignition
Thanks I got it. ‘Device Connectivity’ is the right place for it. However I was unable to get the downloads/ignition page. Thanks a lot.
regards
Hello everyone, I have a small doubt.
I have installed the Ignition in a VM in which I have a DNS as well with SSL for that. For eg: https://link:443
So My requirement is like,
I have the webdev module in trial version.
I have a pdf on my local computer like sample.pdf.
While I tried to see this in pdf viewer in local it was working(Created by using the Webdev-- New file resource-- copy mounted path--added this in pdf component-- HTTP://localhost:443/system/webdev/projectname/sample.pdf),
but when I tried the same in the VM, it is not working, can you please share how I can get it to be done?
The file is in my local. I tried adding https://url:443/system/webdev/.........like that.
I don't know where I'm missing the content
Webdev can't expose directories from your local machine. It can only expose files from wherever the gateway is installed, or you can upload a particular file into Webdev as a 'file' resource type.
