Make sure this is filled by a dataset or jsonobject and after that that the binding is turned off
Summary
[ { "type": "ia.chart.xy", "version": 0, "props": { "title": { "text": "Day Energy Monitor" }, "xAxes": [ { "name": "time", "label": { "enabled": true, "text": "Day", "color": "" }, "visible": true, "tooltip": { "enabled": true, "text": "", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "inversed": false, "render": "date", "category": { "break": { "enabled": false, "startCategory": "", "endCategory": "", "size": 0.05 } }, "date": { "baseInterval": { "enabled": true, "timeUnit": "day", "count": 1, "skipEmptyPeriods": true }, "range": { "max": "", "min": "", "useStrict": false }, "break": { "enabled": false, "startDate": "", "endDate": "", "size": 0.05 }, "inputFormat": "M/d/yyyy HH:mm:ss", "format": "d/M/yy" }, "value": { "range": { "max": "", "min": "", "useStrict": false }, "logarithmic": false, "break": { "enabled": false, "startValue": 0, "endValue": 100, "size": 0.05 }, "format": "#,###.##" }, "appearance": { "opposite": false, "inside": false, "labels": { "color": "", "opacity": 1, "rotation": 90 }, "grid": { "color": "", "opacity": 0, "dashArray": "", "minDistance": 60, "position": 0.5 }, "font": { "size": 9, "weight": 1000 } } } ], "yAxes": [ { "name": "Diff", "label": { "enabled": true, "text": "KWH", "color": "" }, "visible": true, "tooltip": { "enabled": true, "text": "", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "inversed": false, "render": "value", "category": { "break": { "enabled": false, "startCategory": "", "endCategory": "", "size": 0.05 } }, "date": { "baseInterval": { "enabled": true, "timeUnit": "day", "count": 1, "skipEmptyPeriods": true }, "range": { "max": "", "min": "", "useStrict": false }, "break": { "enabled": false, "startDate": "", "endDate": "", "size": 0.05 }, "inputFormat": "yyyy-MM-dd kk:mm:ss", "format": "HH:mm:ss a" }, "value": { "range": { "max": "", "min": "", "useStrict": false }, "logarithmic": false, "break": { "enabled": false, "startValue": 0, "endValue": 100, "size": 0.05 }, "format": "#,###.##" }, "appearance": { "opposite": false, "inside": false, "labels": { "color": "", "opacity": 1 }, "grid": { "color": "", "opacity": 0, "dashArray": "", "minDistance": null, "position": 0.5 }, "font": { "size": 10, "weight": 500 } } } ], "series": [ { "name": "Diff", "label": { "text": "KWH" }, "visible": true, "hiddenInLegend": false, "defaultState": { "visible": true }, "data": { "source": "example", "x": "time", "y": "Diff" }, "xAxis": "time", "yAxis": "Diff", "zIndex": 0, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "render": "line", "candlestick": { "open": { "x": "", "y": "" }, "high": { "x": "", "y": "" }, "low": { "x": "", "y": "" }, "appearance": { "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "stacked": false, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" } }, "heatRules": { "enabled": false, "max": "", "min": "", "dataField": "" } } }, "column": { "open": { "x": "", "y": "" }, "appearance": { "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "stacked": false, "width": null, "height": null, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" } }, "heatRules": { "enabled": false, "max": "", "min": "", "dataField": "" } } }, "line": { "open": { "x": "", "y": "" }, "appearance": { "connect": true, "tensionX": 1, "tensionY": 1, "minDistance": 0.5, "stroke": { "width": 3, "opacity": 1, "color": "", "dashArray": "" }, "fill": { "opacity": 0, "color": "" }, "bullets": [ { "enabled": true, "render": "circle", "width": 10, "height": 10, "label": { "text": "{value}", "position": { "dx": 0, "dy": 0 } }, "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "rotation": 0, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]\nDate: [bold]{dateX}[/]", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" }, "rotation": "" }, "heatRules": { "enabled": false, "max": 100, "min": 2, "dataField": "" } } ] } }, "stepLine": { "open": { "x": "", "y": "" }, "appearance": { "connect": true, "tensionX": 1, "tensionY": 1, "minDistance": 0.5, "stroke": { "width": 3, "opacity": 1, "color": "", "dashArray": "" }, "fill": { "opacity": 0, "color": "" }, "bullets": [ { "enabled": true, "render": "circle", "width": 10, "height": 10, "label": { "text": "{value}", "position": { "dx": 0, "dy": 0 } }, "fill": { "color": "", "opacity": 1 }, "stroke": { "color": "", "opacity": 1, "width": 1 }, "rotation": 0, "tooltip": { "enabled": true, "text": "{name}: [bold]{valueY}[/]", "cornerRadius": 3, "pointerLength": 4, "background": { "color": "", "opacity": 1 } }, "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" }, "rotation": "" }, "heatRules": { "enabled": false, "max": 100, "min": 2, "dataField": "" } } ] } } }, { "candlestick": { "appearance": { "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" } }, "fill": { "color": "", "opacity": 1 }, "heatRules": { "dataField": "", "enabled": false, "max": "", "min": "" }, "stacked": false, "stroke": { "color": "", "opacity": 1, "width": 1 } }, "high": { "x": "", "y": "" }, "low": { "x": "", "y": "" }, "open": { "x": "", "y": "" } }, "column": { "appearance": { "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "stroke": { "color": "", "opacity": "", "width": "" } }, "fill": { "color": "", "opacity": 1 }, "heatRules": { "dataField": "", "enabled": false, "max": "", "min": "" }, "height": null, "stacked": false, "stroke": { "color": "", "opacity": 1, "width": 1 }, "width": null }, "open": { "x": "", "y": "" } }, "data": { "source": "example", "x": "time", "y": "Energy" }, "defaultState": { "visible": true }, "hiddenInLegend": false, "label": { "text": "" }, "line": { "appearance": { "bullets": [ { "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "rotation": "", "stroke": { "color": "", "opacity": "", "width": "" } }, "enabled": false, "fill": { "color": "", "opacity": 1 }, "heatRules": { "dataField": "", "enabled": false, "max": 100, "min": 2 }, "height": 10, "label": { "position": { "dx": 0, "dy": 0 }, "text": "{value}" }, "render": "circle", "rotation": 0, "stroke": { "color": "", "opacity": 1, "width": 1 }, "tooltip": { "background": { "color": "", "opacity": 1 }, "cornerRadius": 3, "enabled": true, "pointerLength": 4, "text": "{name}: [bold]{valueY}[/]" }, "width": 10 } ], "connect": true, "fill": { "color": "", "opacity": 0 }, "minDistance": 0.5, "stroke": { "color": "", "dashArray": "", "opacity": 1, "width": 3 }, "tensionX": 1, "tensionY": 1 }, "open": { "x": "", "y": "" } }, "name": "Energy", "render": "line", "stepLine": { "appearance": { "bullets": [ { "deriveFieldsFromData": { "fill": { "color": "", "opacity": "" }, "rotation": "", "stroke": { "color": "", "opacity": "", "width": "" } }, "enabled": true, "fill": { "color": "", "opacity": 1 }, "heatRules": { "dataField": "", "enabled": false, "max": 100, "min": 2 }, "height": 10, "label": { "position": { "dx": 0, "dy": 0 }, "text": "{value}" }, "render": "circle", "rotation": 0, "stroke": { "color": "", "opacity": 1, "width": 1 }, "tooltip": { "background": { "color": "", "opacity": 1 }, "cornerRadius": 3, "enabled": true, "pointerLength": 4, "text": "{name}: [bold]{valueY}[/]" }, "width": 10 } ], "connect": true, "fill": { "color": "", "opacity": 0 }, "minDistance": 0.5, "stroke": { "color": "", "dashArray": "", "opacity": 1, "width": 3 }, "tensionX": 1, "tensionY": 1 }, "open": { "x": "", "y": "" } }, "tooltip": { "background": { "color": "", "opacity": 1 }, "cornerRadius": 3, "enabled": true, "pointerLength": 4, "text": "{name}: [bold]{valueY}[/]" }, "visible": true, "xAxis": "time", "yAxis": "diff", "zIndex": 0 } ], "style": { "backgroundColor": "#FFFFFF" }, "dataSources": { "example": { "$": [ "ds", 192, 1646305892764 ], "$columns": [ { "name": "time", "data": [], "type": "Date" }, { "name": "kwh", "data": [], "type": "Double" }, { "name": "Minimum", "data": [], "type": "Double" }, { "name": "Maximum", "data": [], "type": "Double" }, { "name": "Diff", "data": [], "type": "Double" }, { "name": "energy", "data": [], "type": "String" } ] } } }, "meta": { "name": "XYChart_0" }, "position": { "x": 123, "y": 474.66700000000003, "height": 281, "width": 1235 }, "custom": {}, "propConfig": { "props.dataSources.example": { "binding": { "type": "property", "enabled": false, "config": { "path": "" } } } } } ]
Well… there is a dataset in it but its empty xd
