readBytesAsString Error
Hi there
Good day
i run system.serial.readBytesAsString() and find that the return value is sometimes incomplete
for example:
The string Scaned: test123456789
sometime the string returned in value:
test12345 or test or test123456
There are no rules
def readData(rootContainer=event.source.parent):
	Port=rootContainer.ScanCom1
	print 'present COM',Port
	recv=''
	errMsg=''
	try:
		system.serial.configureSerialPort(\
		port=Port,\
		bitRate=system.serial.BIT_RATE_115200,\
		dataBits=system.serial.DATA_BITS_8,\
		handshake=system.serial.HANDSHAKE_NONE,\
		hardwareFlowControl=False,\
		parity=system.serial.PARITY_NONE,\
		stopBits=system.serial.STOP_BITS_1)
		system.serial.openSerialPort(Port)
#		www=system.serial.readBytes(Port,10)
#		print 'byte',www
		recv=system.serial.readBytesAsString(Port,50,10000)
#		recv=system.serial.readLine(Port,10000)
		print recv+'wwwwww'
		if recv:
			print recv,len(recv)
		else:
			errMsg=u'接收空数据'
		system.serial.closeSerialPort(Port)
	except   :
		errMsg=u'打开串口失败或通讯超时'
	def sendBack(recv=recv,errMsg=errMsg,rootContainer=rootContainer):
		import system
		if recv:
			rootContainer.getComponent('txtscan 1').ScanData=recv
		print 'newerr--------------->',errMsg
		rootContainer.getComponent('lberr 1').text=errMsg
		if errMsg=='':
			event.source.doClick()
	system.util.invokeLater(sendBack)
system.util.invokeAsynchronous(readData)
* List item
