Weird OPC Tag Name Issue with Logix v32
Has anyone else noticed a strange bug with Ignition’s OPC UA module in 7.9.10 communicating with a ControlLogix PLC with firmware v32 where when a tag name is changed in the PLC the name change is not reflected in the OPC Browser after a refresh and reading/writing to the tag still works with the old PLC tag name in the tag properties?
A workaround at this moment is deleting the device from the gateway entirely and adding the device back which makes the OPC Browser work as intended (tag name changes are reflected after a refresh) however after restarting the OS that is hosting the gateway the bug comes back.
Thanks.
