I have a numeric text field which has its integer value bound to the PLC tag, but also I scripted it to write to the tag as well. User can type in a number - press Enter - value writes to the tag. The problem is that every once in a while - 1 shows up in the field and messes up the tag. I have the tag set up to accept only the range of 0 to 200 and nothing else. What causes -1 to show up in the field? —Is it the OPC problem? How to prevent it from showing and writing to the PLC tag? So, I want the number that is entered to stay in the text field unless someone changes it.
[quote=“pstojakovic”]I have a numeric text field which has its integer value bound to the PLC tag, but also I scripted it to write to the tag as well. User can type in a number - press Enter - value writes to the tag. The problem is that every once in a while - 1 shows up in the field and messes up the tag. I have the tag set up to accept only the range of 0 to 200 and nothing else. What causes -1 to show up in the field? —Is it the OPC problem? How to prevent it from showing and writing to the PLC tag? So, I want the number that is entered to stay in the text field unless someone changes it.
Thanks.[/quote]
Same is happening by me also… Nobody?
What kind of script are you using to write the value to the tag? Is it a propertyChange script?
Why are you writing the value to the tag with a script? A bidirectional binding on the component would allow you to write a value back to the tag and you would not need to script the write.
[quote=“Greg.Simpson”]What kind of script are you using to write the value to the tag? Is it a propertyChange script?
Why are you writing the value to the tag with a script? A bidirectional binding on the component would allow you to write a value back to the tag and you would not need to script the write.[/quote]
If it would be that simple…
I’m using numeric text field in the template for converting the integer (milliseconds) to Siemens Simatic PLC timer format (S5Time). And that requires some custom tag types and ‘some’ scripting…
