We have an Ignition server running on 7.9.10 this server is used as an “I/O-server” for two different front end Ignition servers. This I/O-server hosts all of our tags.
When I run the “system.tag.exists” on the other front end gateway that is running V8.0 to check if the tag exists on the remote gateway the script will result to ‘false’ even though I can see that the tag does exist as it is shown on my Tag browser in designer.
(The tag path is correct.)
Tags are brought in with remote tag provider.
Also the Tag Browser only shows the value and Data type of the tags, but nothing else. So no “last cahnge” metadata or anything else.
