2 sessions, but 4 queries
Ignition 7.8.5
I have a query to populate a table. And it seems the database faults when too much data is queried.
I also noticed 4/8 and at one point 7/8 DB connections. Even though I have 1 project session and 1 designer open. So at max I'd think only 2/8 should be active.
Any ideas what's going on here?
Your queries are taking > 30 minutes. I'm surprised they haven't timed out.
The WHERE clauses don't look that complex.
  1. Are the t_stamp columns DATETIME types (and not STRING)?
  2. Are you sure your database has indexes on main.t_stamp and sub.t_stamp?
If i look at a days worth of data it is fine, but times out when larger pools are done.
This is how the values get into the DB:
the date compare is off a text box, and i read the text in the container.
Your screengrab shows the structure of your transaction group which is putting data into your database. Your original post shows problems with SELECT statements which are getting data out of your database.
I'm suggesting that you examine the database structure, check the t_stamp column types and the presence or absence of indices on the t_stamp columns.
Here is a pic of the DB datatypes
OK, the t_stamp column is DATETIME so that's OK.
Can you use your database administration tool to find if there is an index on the t_stamp columns in the main and sub tables?
ahhhhh. I don't see sub and main tables.
I think you're missing some database management skills here - or maybe you don't have permissions to administer the database. We still don't know if your t_stamp colums are indexed.
During database installation it is normal to include an administration tool which allows creation / editing / deletion of database and tables and, what we're looking for, the indexes. The indexing creates a list of all the records sorted by one or more columns specified in the index definition. Setting this up allows much, much faster query times.
  1. What flavour of SQL are you running? MariaDB / MySQL, MS SQL, PostgreSQL, Oracle or something else?
  2. Do you have administration rights to the database - or a contact who does?
  3. Can you find the administration tool? e.g., For MySQL / MariaDB MySqlWorkbench is popular.
I think its MySQL 5.1
I don't have access to the DB. I'm going to have to coordinate with IT and the in house guy there.
Let's see if we can figure it out using Ignition's Named Query editor. Try this:
  • Go to Project Browser | Named Queries.
  • Create a new blank query "IndexCheck".
  • Open the Authoring tab.
  • From the Database Connections dropdown select your database. Your main and sub table names should now appear in the Table Browser on the right of the window.
  • In the Query text area, enter the following:
    SHOW INDEXES FROM xxxxxx
    Replace xxxxx with the name of your either your main or sub table (listed in the Table Browser).
  • Open the Testing tab.
  • Hit Execute Query.
Post a nicely cropped screengrab here, showing the column headers and data for columns Table through to Collation. It should look something like this.
When you have time, take a scan through this document. (It's a random one from a quick search on the topic.)
MySQL Show Indexes: Practical Examples and GUI Techniques.
I am using version 7.8.5 which is prior the release of named queries.
I was able to get data types in the query browser. Having a tough time with indexes
@Transistor Got this of the index from inside designer.
Definitely no access to where the MySQL is hosted. But sent request to IT.
From post #9:
Did you try that?
SHOW INDEXES FROM wastewaterlog in your case.
Yes,
That responds in a different way to my 8.1 system as shown in post #9.
Let's see what your IT guys can demonstrate.
Going to put an archived version of workbench on the pc I have access to and hope it lets me do a remote connection. I'll keep you posted.
That old Ignition version can only do query/update autoselect, and it gets it wrong for that kind of meta-command.
IT got me access to the serve, I was able to pull this from the command line tool.
Can you cut and paste that as formatted text, please? See Wiki - how to post code on this forum. That way the columns will line up and my head won't hurt.
In the jumble it appears that wastewaterlog has
  • Key_name: WastWaterLogt_stampndx
    based on
  • Column_name: t_stamp
    so that should be indexed properly.
Wasn't there a second table to be checked?
