I mentioned in a post somewhere that I made 3 new Ignition Exchange resources during downtime at ICC (after ICC events). Those resources are now through the approval process. Nothing groundbreaking but probably useful for people doing legacy SCADA upgrades. I basically took things I used in various projects and made them accessible to the community.
The first is an SVG-based indicator light. It's basically the same SVG as another resource I posted a couple years ago but with some blend modes to make color animations look nice. I used HSL for the colors so Nick is probably smiling. He was right about that.
The second is an animated flame. I'm sure we've all seen fire animations in legacy SCADA upgrades. I made this one for that exact situation.
The third is an animated screw conveyor. I put comments in the style sheet to explain how it works because people may want to have similar behavior with other drawings. You can use it as a non-animated screw conveyor with the one style and the other style does an animation within the SVG definition in the CSS. I did it this way so it would repeat elements when resized on the X axis and it would increase the size of the segments when resized on the Y axis.
