32-bit Vision Client Ignition 8.0
“As of Ignition 8, 32-bit Vision Client support was dropped; the availability of 32-bit Java Runtime Environments (JRE) will diminish overtime as the technology is slowly deprecated.”
Is there a systems requirement list for the Vision Client on Ignition 8.0?
This is all I found but it doesn’t mention the 32-bit vision client or JRE/JDK 11 requirements.
32-bit platforms (except ARM) are not supported for Vision. But there is a serviceable workaround for now. The system requirements vary quite a bit depending on your project so it would be difficult to specify these (although stating a 64-bit system should be added).
https://support.inductiveautomation.com/index.php?/Knowledgebase/Article/View/127/0/ignition-8-32-bit-vision-clients
