3D array in ignition?
Im trying to use 3D array in ignition. Array [1..10,1..10,1..7] of bool. But in ignition it apears like this [0..700]. Is it not possible to use multi dimension array?
Where is "value" in your project?
Its in the tag browser:
Not possible.
Perhaps this is an example of the XY problem.
If you describe what you are tying to accomplish, someone might have a solution that will work for you.
