I am using 7.4 and Cannot Import Window (vwin) file. What is up with that? Will someone help me out here? ![]()
You can. You just need to hold down Shift when you right click on the Windows folder. You will see a Legacy Import (vwin) in the list.
Going forward, the shift-right click option is gone (as of 7.4.3). The normal import will let you choose either a legacy .vwin file or a .proj file.
