Wow, 7.5.2 has some issues.
First issue is that I had a table with a cell update property and after the update from 7.5.1 to 7.5.2 it would not work at all, just had the following error:
[quote]User
Doug Keller
dkeller@clemensfoodgroup.com
User Message
I’m getting this error on a table with a cell update property. I only started getting this error right after upgrading to 7.5.2. I’m updating cells of a table with SQL tags, it’s worked fine since 7.3 but now I’m getting an error.
Error Message
Uncaught NumberFormatException: For input string: “0.0”
Error Details
java.lang.NumberFormatException: For input string: “0.0”
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at com.inductiveautomation.ignition.common.TypeUtilities.coerceLocaleSafe(TypeUtilities.java:708)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.eval(CellUpdateAdapter.java:161)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.eval(CellUpdateAdapter.java:120)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.access$000(CellUpdateAdapter.java:29)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter$1.run(CellUpdateAdapter.java:201)
at com.inductiveautomation.ignition.client.util.EDTUtil$ProcessQueue.run(EDTUtil.java:110)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
System Details
fpmi.client.memory.used=287.63
fpmi.client.memory.max=455.13
fpmi.client.type=Designer
fpmi.client.version=7.5.2 (b1146)
java.vm.version=19.1-b02
java.vm.vendor=Sun Microsystems Inc.
java.vm.name=Java HotSpot™ 64-Bit Server VM
user.country=US
os.name=Windows 7
os.arch=amd64
sun.os.patch.level=Service Pack 1
os.version=6.1
java.specification.version=1.6
user.language=en
ignition.gateway.version=7.5.2 (b1146)
ignition.gateway.memory.used=265.63
ignition.gateway.memory.max=1019.88
ignition.gateway.uptime=36 minutes, 56 seconds
ignition.module.xopc-drivers=1.5.1 (b235) - RUNNING
ignition.module.mobile=1.5.1 (b153) - RUNNING
ignition.module.modbus-driver2=2.5.1 (b219) - RUNNING
ignition.module.xopc=1.5.1 (b431) - RUNNING
ignition.module.opccom=1.5.1 (b147) - RUNNING
ignition.module.rept=1.5.0 (b145) - LOADED
ignition.module.siemens-drivers=1.5.0 (b152) - RUNNING
ignition.module.fsql=5.5.0 (b207) - RUNNING
ignition.module.symfact=2.6.0 (b35) - RUNNING
ignition.module.udp-driver=1.5.2 (b156) - RUNNING
ignition.module.help=1.5.0 (b271) - RUNNING
ignition.module.meshelp=1.5.0 (b7) - RUNNING
ignition.module.fpmi=6.5.2 (b662) - RUNNING
user.country=US
os.name=Windows 7
os.arch=amd64
os.version=6.1
user.language=en
[/quote]
I also have a page full of templates and that page would no longer open with the following error:
[quote]User
Doug Keller
User Message
I’ve got a page with a bunch of templates that will not open, it just throws this error. This happened after the update from 7.5.1 to 7.5.2.
Error Message
Error executing script for event: actionPerformed
on component: Syncronization.
Error Details
File “”, line 6, in
at sun.misc.FloatingDecimal.readJavaFormatString(Unknown Source)
at java.lang.Double.parseDouble(Unknown Source)
at com.inductiveautomation.ignition.common.TypeUtilities.coerceLocaleSafe(TypeUtilities.java:702)
at com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.startup(CellUpdateAdapter.java:75)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupAdapters(DefaultInteractionController.java:304)
at com.inductiveautomation.factorypmi.application.components.template.VisionTemplate.startup(VisionTemplate.java:147)
at com.inductiveautomation.factorypmi.application.components.template.TemplateHolder.startupTemplate(TemplateHolder.java:387)
at com.inductiveautomation.factorypmi.application.components.template.TemplateHolder.loadTemplate(TemplateHolder.java:247)
at com.inductiveautomation.factorypmi.application.components.template.TemplateHolder.initTemplate(TemplateHolder.java:441)
at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor$TemplateHolderVisitor.visit(ComponentVisitor.java:107)
at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor.walk(ComponentVisitor.java:58)
at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor.walk(ComponentVisitor.java:40)
at com.inductiveautomation.factorypmi.application.FPMIWindow.initialize(FPMIWindow.java:262)
at com.inductiveautomation.factorypmi.application.FPMIApp$RuntimeWindowOpener.openWindow(FPMIApp.java:1558)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:883)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:875)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$1.run(NavUtilities.java:201)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:608)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapWindow(NavUtilities.java:199)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapTo(NavUtilities.java:111)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapTo(NavUtilities.java:92)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.NumberFormatException: java.lang.NumberFormatException: For input string: “null”
at org.python.core.PyException.fillInStackTrace(PyException.java:70)
at java.lang.Throwable.(Throwable.java:181)
at java.lang.Exception.(Unknown Source)
at java.lang.RuntimeException.(Unknown Source)
at org.python.core.PyException.(PyException.java:46)
at org.python.core.PyException.(PyException.java:43)
at org.python.core.Py.JavaError(Py.java:481)
at org.python.core.Py.JavaError(Py.java:474)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:455)
at org.python.core.PyObject.__call__(PyObject.java:387)
at org.python.core.PyObject.__call__(PyObject.java:391)
at org.python.pycode._pyx8.f$0(:6)
at org.python.pycode._pyx8.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1261)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:539)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:155)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:266)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at $Proxy15.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
Caused by: java.lang.NumberFormatException: For input string: “null”
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
… 50 more
System Details
fpmi.client.memory.used=136.41
fpmi.client.memory.max=247.50
fpmi.client.type=null
fpmi.client.version=null
java.vm.name=Java HotSpot™ Client VM
user.country=US
os.name=Windows XP
os.arch=x86
sun.os.patch.level=Service Pack 3
os.version=5.1
user.language=en
ignition.gateway.uptime=56 minutes, 27 seconds
user.country=US
os.name=Windows XP
os.arch=x86
os.version=5.1
user.language=en
[/quote]
When I opened the designer it would not even let me open the template to see what the problem was, no error it just wouldn’t let me open it at all. Needless to say, I had to revert back to 7.5.1 to get everything working again. FYI.
