7.5.7 startup error- JVM exited while loading the appli
i just installed 7.5.7 on my dev system and can’t start the service.
OS is Windows XP, Java 1.7.0_13
Has to be a problem on my side, as returning to 7.5.7 beta4 (which worked) does not fix the problem. Any ideas what could cause this?
STATUS | wrapper  | 2013/04/24 20:20:51 | --> Wrapper Started as Service
STATUS | wrapper  | 2013/04/24 20:20:51 | Java Service Wrapper Standard Edition 32-bit 3.5.15
STATUS | wrapper  | 2013/04/24 20:20:51 |   Copyright (C) 1999-2012 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper  | 2013/04/24 20:20:51 |     http://wrapper.tanukisoftware.com
STATUS | wrapper  | 2013/04/24 20:20:51 |   Licensed to Inductive Automation for Ignition Gateway
STATUS | wrapper  | 2013/04/24 20:20:51 | Launching a JVM...
INFO   | jvm 1    | 2013/04/24 20:20:52 | WrapperManager: Initializing...
INFO   | jvm 1    | 2013/04/24 20:20:52 | WrapperSimpleApp Error: Class com.inductiveautomation.catapult.Catapult found but could not be initialized: java.lang.NoClassDefFoundError: org/apache/catalina/LifecycleListener
INFO   | jvm 1    | 2013/04/24 20:20:54 | Please use CMSClassUnloadingEnabled in place of CMSPermGenSweepingEnabled in the future
ERROR  | wrapper  | 2013/04/24 20:20:54 | JVM exited while loading the application.
Ok, after a complete clean install everything is running.
This is odd, either the catapult.jar in the Ignition/lib folder got corrupted somehow, or is missing. I’d ask for your install_log.txt but it would’ve been overwritten by your clean install. In any case, glad you got it working again.
