System: Debian Squeeze
Java :
java version “1.6.0_26”
Java™ SE Runtime Environment (build 1.6.0_26-b03)
Java HotSpot™ 64-Bit Server VM (build 20.1-b02, mixed mode)
Problem: After updating apt
deb archive.inductiveautomation.com/apt ignition non-free
apt-get update
apt-get upgrade
And installing the latest ignition
apt-get install ignition
I can no longer access the gateway web server (192.168.8.68:8088/main/)
Resulting message…
HTTP Status 404 -
type Status report
message
description The requested resource is not available.
Apache Tomcat/6.0.36
I have checked all the xml files I could find. some had “^M” line endings which I fixed
(with perl -p -i -e ‘s/\r\n$/\n/g’ ) but nothing significant was wrong.
/var/lib/ignition/data/gateway.xml
/usr/local/bin/ignition/tomcat/webapps/main/META- INF/maven/com.inductiveautomation.ignition/bootstrap/pom.xml
/usr/local/bin/ignition/tomcat/webapps/main/WEB-INF/web.xml
/usr/local/bin/ignition/tomcat/webapps/ROOT/WEB-INF/web.xml
/usr/local/bin/ignition/tomcat/conf/web.xml
/etc/ignition/gateway.xml
I have attached a minimized version of wrapper.log which shows some significant errors
but I do not know what to do with them.
Here is one…
INFO | jvm 1 | 2013/09/06 16:45:16 | SLF4J: slf4j-api 1.6.x (or later) is incompatible with this binding.
INFO | jvm 1 | 2013/09/06 16:45:16 | SLF4J: Your binding is version 1.5.5 or earlier.
INFO | jvm 1 | 2013/09/06 16:45:16 | SLF4J: Upgrade your binding to version 1.6.x.
INFO | jvm 1 | 2013/09/06 16:45:16 | Sep 6, 2013 4:45:16 PM org.apache.catalina.core.StandardContext filterStart
INFO | jvm 1 | 2013/09/06 16:45:16 | SEVERE: Exception starting filter WicketFilter
INFO | jvm 1 | 2013/09/06 16:45:16 | java.lang.NoSuchMethodError: org.slf4j.impl.StaticLoggerBinder.getSingleton()Lorg/slf4j/impl/StaticLoggerBinder;
And the other…
INFO | jvm 1 | 2013/09/06 16:45:16 | Sep 6, 2013 4:45:16 PM org.apache.catalina.core.StandardContext start
INFO | jvm 1 | 2013/09/06 16:45:16 | SEVERE: Error filterStart
INFO | jvm 1 | 2013/09/06 16:45:16 | SEVERE: Context [/main] startup failed due to previous errors
I would appreciate any help.
–Doug
