Creating frame. extendedState=6, bounds=java.awt.Rectangle[x=0,y=0,width=1024,height=768]
INFO [GatewayConnectionManager-Thread-15] Skipping local challenge - directory doesn't exist.
INFO [Gateway-Thread-15] Starting up polling tag manager, polling rate: 250 ms
INFO [ReportingClientHook-Thread-15] Starting up Reporting Module. Mode: Trial
Initializing ReportMill (Build Date: May-27-05, Version 9.0, JVM 25.31-b07, User XXXXXXX)
INFO [FPMIApp-AWT-EventQueue-2] Starting Up...
Retargeting property binding for renamed property. DeleteRowButton.enabled is now DeleteRowButton.componentEnabled
Retargeting property binding for renamed property. VendorDropdown.enabled is now VendorDropdown.componentEnabled
Retargeting property binding for renamed property. Button 2.enabled is now Button 2.componentEnabled
Have 2 questions on what they mean:
and these:
I searched through the project and can not find these buttons by them names.
I see these on both versions of gateway server and just doing some testing before going to new version. They are in diagnostics right after project loads.
What they mean and how can I fix, don’t seem to be causing any problems.
