In expression binding…if you are trying to access a value from a dataset with a index and column name you have to add toInt(index) otherwise you get an error saying that it’s expecting an int and you are providing a long.
this no longer works:
{Root Container.Data}[0,{Root Container.DateTime 1.ColumnName}]
this is what i have to do now:
{Root Container.Data}[toInt(0),{Root Container.DateTime 1.ColumnName}]
Existing expressions after the update seem to work fine. If you attempt to modify an existing expression or create a new one with that type of expression you get the error.
