Firstly, if you want to use a parameter, in this case StartDate, try changing your SQL query to:
SELECT * FROM tbl_turbineData WHERE t_stamp > ?
The ‘?’ will unlock the Parameter 1 field below the query where you can now select {StartDate} from the defined Parameters (3rd icon down)
If you are still having problems with the SQL formatting of the date and depending on your t_stamp field and SQL version, you may need to use the CAST (expression AS data_type) Function.
I do and use the following to get all fields where the day was yesterday.
SELECT * FROM sometable WHERE CAST(date AS DATE) = CAST(GETDATE() - 1 AS DATE)
