Hi Guys,
So I upgraded a GW from 7.9.5 to 7.9.7. My tags out of my L33 CompactLogix are having overlay issues. I think I can read data using OPC Quick Client.
The logs report an “Uncaught Throwable during Execution”
at com.inductivautomation.xopc.drivers.logix.browse.LogixBrowseState.tag(LogixBrowseState.java:83)
I also read 7.9.7 had Update Query issues. Which I did notice that on a Dev Gateway I had with 7.9.7. I kept having to recreate Objects cause I was getting UPDATE Query errors.
Then I found the Posts where people explained the Update Checkbox got turned on in 7.9.7. Yikes
Is there a Known Issues List for Versions? Or just have to check Forums? I looked at Change log but that lists what is Fixed.
I already Uninstalled 7.9.7 and reinstalled 7.9.5. Just about to reload the 7.9.5 backup I Took. But it seems like the Projects were still on Gateway after Installing 7.9.5. I don’t know if I trust the projects after they were upgraded to 7.9.7 and now they just opened up on the Reinstalled 7.9.5. The projects weren’t Deleted during “uninstall”, which I guess is good.
I think I am going to “reload” the 7.9.5 GW backup I took before the upgrade.
