I found the link that describes Linux command line options for unattended installation. https://docs.inductiveautomation.com/display/DOC80/Command+Line+Installations
Is it possible to designate the modules that are installed?
One thing that I can offer here is that you can simply rm the modules you don’t want from the user-lib/modules folder after install… Should be a simple one-liner after the call to the Ignition installer.
