Maybe look at the console and wrapper logs?
In the designer launcher, are you using IP or DNS? There is a known issue, external to Ignition, using DNS. Use IP.
If it is a DNS issue and you’re on Windows, CMD ipconfig/flushdns has worked well to bring the connection back for me. We figured out there were some DNS issues on corporate network and I rarely run into this since those were resolved.
@Matrix_Engineering, I wasn’t aware of a known issue with DNS and designer launcher. Any more details? Would this affect clients too?
It's a different error message, connection lost to Gateway:
I'm having similar DNS issues at the moment - at home, so I've got no 'IT support' to help - something is causing my Gateway Ubuntu VM to stop resolving every 2 to 3 hours.
The cause of the issue is obviously mine to correct, but what's annoying is that Perspective designer throws up 'connection lost' errors every second and floods the system with message boxes that I can't get rid of. Is there anything that can be done to reduce the flood of messages???
