The obvious way to test would be to put the video on the Gateway and try it that way. In theory what you're currently doing shouldn't be a problem, and sounds like maybe it has to do with the connection between the file server and the session. Have you tried other videos longer than this amount of time on that same file server?
Hey, sorry to not reply sooner. Thank you for your reply! It turned out that in the first video there was an issue with the video that was observable in other video players, like Windows Media Player. However, with a good video, I have found that the video freezes at random times. In this case it's a 6 min video that I am looping. When it eventually freezes, I get this error (with the items in <> not put for OPSEC reasons):
GET GATEWAY/keepalive/<PROJECT_NAME>/67e1a8e/1444775978576768 net::ERR_CONNECTION_TIMED_OUT
onerrorLogger: {"stack":"Error: Network Error\n at e.exports (GATEWAY/res/perspective/js/PerspectiveClient.ff45021c636db233995f.js:6:187436)\n at m.onerror (GATEWAY/res/perspective/js/PerspectiveClient.ff45021c636db233995f.js:6:186419)","message":"Network Error","name":"Error","logData":{"msg":"unhandledrejection","errorMsg":"Network Error"}}
Uncaught (in promise) Error: Network Error
at e.exports (PerspectiveClient.ff45021c636db233995f.js:6:187436)
at m.onerror (PerspectiveClient.ff45021c636db233995f.js:6:186419)
I let it sit for a while, maybe 5 minutes, and it eventually seemed to recover, but I'm curious if there is a way to handle this error. I don't think 'wait and see if it recovers' will fly with our end-users
GET GATEWAY/system/webdev/<PROJECT_NAME>/videos/<VIDEO_NAME>.mp4 net::ERR_CONNECTION_RESET 200 (OK)
We'll need to look into it, but what looks to be happening is that your Session's connection to the Gateway is being interrupted, and so the download/buffering of the video is halted. The root cause is going to be almost impossible to nail down because any environment is understandably going to be an exact match to your configuration. I have someone looking at this at the surface level to see what could be happening.
We're pretty limited in what we can do here on the forum, but it's being recommended that you grab as many logs as you can (and a thread dump if you're familiar with that process) and get in contact with Support as they'll have more readily-available resources to assist in replication/troubleshooting.
