8.1.25 Failing to create GWBK
As per title, 8.1.25 (b2023021409)
Server Ubuntu 20.04.5 LTS
Trying to download GWBK using Chrome from gateway web page on a Win 10 box
org.eclipse.jetty.io.EofException: null
at org.eclipse.jetty.io.SocketChannelEndPoint.flush(SocketChannelEndPoint.java:116)
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422)
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:275)
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:254)
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:386)
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:827)
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:232)
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:214)
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:584)
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:1060)
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:1132)
at org.eclipse.jetty.server.HttpOutput.channelWrite(HttpOutput.java:270)
at org.eclipse.jetty.server.HttpOutput.channelWrite(HttpOutput.java:254)
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:858)
at java.base/java.util.zip.DeflaterOutputStream.deflate(Unknown Source)
at java.base/java.util.zip.DeflaterOutputStream.write(Unknown Source)
at java.base/java.util.zip.ZipOutputStream.write(Unknown Source)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.addFile(BackupServlet.java:323)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.generateBackup(BackupServlet.java:186)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.doBackup(BackupServlet.java:164)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.doGet(BackupServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:503)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1383)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1305)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:934)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1078)
Caused by: java.io.IOException: Broken pipe
at java.base/sun.nio.ch.FileDispatcherImpl.writev0(Native Method)
at java.base/sun.nio.ch.SocketDispatcher.writev(Unknown Source)
at java.base/sun.nio.ch.IOUtil.write(Unknown Source)
at java.base/sun.nio.ch.SocketChannelImpl.write(Unknown Source)
at java.base/java.nio.channels.SocketChannel.write(Unknown Source)
at org.eclipse.jetty.io.SocketChannelEndPoint.flush(SocketChannelEndPoint.java:110)
HttpChannel	07Mar2023 21:36:50	/system/backup/partial
java.lang.IllegalStateException: ABORTED
at org.eclipse.jetty.server.HttpChannelState.sendError(HttpChannelState.java:911)
at org.eclipse.jetty.server.Response.sendError(Response.java:498)
at com.inductiveautomation.ignition.gateway.servlets.BackupServlet.doBackup(BackupServlet.java:167)
Hmm, it's a headed server, so I used Firefox on the bare metal and it downloaded a 15.8MB GWBK instantly. Perhaps something fishy on my network, there's a UDM Pro but shouldn't be interfering with anything on the same subnet.
Definitely something up with the network. Does obtaining a gwbk locally with gwcmd work?
Yup
There are 2 switches between the server and the UDM pro. I rebooted both the switches, and now I can generate a remote GWBK using the gateway web page.
