I am trying to use a dataset query tag that is setup on an 8.1.37 gateway through a remote tag provider to a 7.9.21 gateway. When I try to view the tag in the tag browser on the 7.9 gateway I get the below error. If I make the tag a memory tag with a dataset it works fine, or I make the query return an integer rather than a dataset it also works fine. The issue seems to only be dataset query tags.
Error loading children.
java.lang.RuntimeException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:536)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:520)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.browse(ClientTagManagerImpl.java:336)
at com.inductiveautomation.ignition.client.sqltags.tree.TagTreeNode.loadChildren(TagTreeNode.java:267)
at com.inductiveautomation.ignition.client.sqltags.tree.TagTreeNode.loadChildren(TagTreeNode.java:325)
at com.inductiveautomation.ignition.client.sqltags.tree.TagTreeNode.checkChildren(TagTreeNode.java:206)
at com.inductiveautomation.ignition.client.sqltags.tree.AbstractTagPathTreeNode.reload(AbstractTagPathTreeNode.java:382)
at com.inductiveautomation.ignition.designer.sqltags.action.RefreshAction.actionPerformed(RefreshAction.java:48)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:353)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:327)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:280)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:912)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:533)
... 46 more
Caused by: java.lang.reflect.UndeclaredThrowableException
at com.sun.proxy.$Proxy16.browse(null)
at com.inductiveautomation.ignition.gateway.sqltags.distributed.client.RemoteTagProvider.browse(RemoteTagProvider.java:358)
at com.inductiveautomation.ignition.gateway.sqltags.SQLTagsManagerImpl.browse(SQLTagsManagerImpl.java:542)
at com.inductiveautomation.ignition.gateway.project.ProjectSettingsCache$ProjectDefaultTagManagerFacade.browse(ProjectSettingsCache.java:612)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.SQLTags.browse(SQLTags.java:170)
at sun.reflect.GeneratedMethodAccessor107.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:211)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1450)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1631)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.lang.Thread.run(Thread.java:748)
Ignition v7.9.21 (b2022072613)
Java: Azul Systems, Inc. 9.0.7.4
