8.1 Server not properly adding UDTs on connection to 7.9 Remote Tag Provider
Currently Upgrading our production server from Ignition 7.9 to Ignition 8.1.53. We have a 12+ Remote tag providers that are all running on Ignition 7.9 now, and are not currently supported in the upgrade. The documentation for the upgrade indicates that they should be backwards compatible, however on adding the Remote Tag provider through the Gateway network, when I browse the tags on the new 8.1 server, there are no UDT instances, and thus the actual tags have all been corrupted somehow, and can not determine anything about themselves (tag type, scripting on tags etc.) See screenshots for more information. Do I need to manually edit the provider on the 8.1 gateway by exporting the tags from the 7.9 remote tag provider, and overriding everything that it is reading?
8.1 New Prod Server UDT empty Folder:
8.1 New Prod Server tags not defined as tag types, with no meta data -> all should be within an instance of a UDT:
7.9 Existing Prod Server UDTs in the Fermentation folder exist (sorry blocked out just for privacy reasons)
7.9 Can see UDT instance is defined from the FERMENTATION folder and all tags populate with tag types
Any thing helps thanks!
