8.1 to 8.3 Database Query Browser different behavor with SQL Server schema tables, columns issue
Between 8.1 and 8.3 behavior was changed with the database query browser with how it sees tables from sql server. In the database I am working on there are many schemas with similar structure, and though it never showed the schema, it did show a table per schema like so -
Now in 8.3 it only shows one table name across all the schemas -
For both 8.1 and 8.3 you open it up the columns are mangled - it seems like a column per table per schema
Would be nice if this was fixed as a small quality of life improvement if possible
I know the schema in sql server doesn't generalize to all databases so I can live with not having that listed, but i do think each table should only show its own columns, not a copy of each column per schema.table that shares the same name.
Can you send this in to support?
Just emailed it in.
Ticket 184473
When configuring a database connection under SQL Compatibilty there is this checkbox
Selecting True fixed the issue for me in 8.3 I then saw SchemaName.TableName and the columns were correctly listed. Did not test in my 8.1 prod live but I assume it will work there too.
