8.3.3 : GSON serialization a PyAlarmEvent object
I’m trying to send a PyAlarmEvent object com.inductiveautomation.ignition.common.alarming.PyAlarmEvent through the GatewayNetwork or to the Session , but since upgrading to 8.3, the sendMessage function call returns an error.
After investigating, it seems that the issue is related to GSON object serialization (Protobuf)).
A basic sample to illustrate:
results = system.alarm.queryStatus(source = "*")
anAlarm = system.util.jsonEncode(results[0])
@paul-griffith
Does anyone have a workaround to achieve this?
I assume the remote provider already handles this kind of operation?
com.inductiveautomation.ignition.common.gson.JsonIOException: Failed making field 'java.lang.ref.Reference#referent' accessible; either increase its visibility or write a custom TypeAdapter for its declaring type.
at com.inductiveautomation.ignition.common.gson.internal.reflect.ReflectionHelper.makeAccessible(ReflectionHelper.java:38)
at com.inductiveautomation.ignition.common.gson.internal.bind.ReflectiveTypeAdapterFactory.getBoundFields(ReflectiveTypeAdapterFactory.java:286)
at com.inductiveautomation.ignition.common.gson.internal.bind.ReflectiveTypeAdapterFactory.create(ReflectiveTypeAdapterFactory.java:130)
at com.inductiveautomation.ignition.common.gson.Gson.getAdapter(Gson.java:556)
at com.inductiveautomation.ignition.common.gson.internal.bind.CollectionTypeAdapterFactory.create(CollectionTypeAdapterFactory.java:53)
at com.inductiveautomation.ignition.common.gson.internal.bind.ReflectiveTypeAdapterFactory.createBoundField(ReflectiveTypeAdapterFactory.java:160)
at com.inductiveautomation.ignition.common.gson.internal.bind.ReflectiveTypeAdapterFactory.getBoundFields(ReflectiveTypeAdapterFactory.java:294)
at com.inductiveautomation.ignition.common.gson.Gson.toJson(Gson.java:834)
at com.inductiveautomation.ignition.common.gson.Gson.toJsonTree(Gson.java:712)
at com.inductiveautomation.ignition.common.gson.Gson.toJsonTree(Gson.java:689)
at com.inductiveautomation.ignition.common.TypeUtilities.pyToGson(TypeUtilities.java:2228)
at com.inductiveautomation.ignition.common.TypeUtilities.pyToGson(TypeUtilities.java:2185)
at com.inductiveautomation.ignition.common.script.builtin.SystemUtilities.jsonEncode(SystemUtilities.java:394)
at jdk.internal.reflect.GeneratedMethodAccessor102.invoke(Unknown Source)
at org.python.core.PyReflectedFunction._call_(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction._call_(ScriptManager.java:561)
at org.python.core.PyObject._call_(PyObject.java:461)
at org.python.core.PyObject._call_(PyObject.java:465)
at org.python.pycode._pyx4842.transform$1(:7)
at org.python.pycode._pyx4842.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction._call_(PyFunction.java:469)
at org.python.core.PyFunction._call_(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:855)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:838)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:1153)
at com.inductiveautomation.perspective.gateway.binding.transforms.script.ScriptTransform.runFunction(ScriptTransform.java:125)
at com.inductiveautomation.perspective.gateway.binding.transforms.script.ScriptTransform.synchronousTransformInternal(ScriptTransform.java:173)
at com.inductiveautomation.perspective.gateway.binding.transforms.AbstractSynchronousTransform.transform(AbstractSynchronousTransform.java:31)
at com.inductiveautomation.perspective.gateway.model.AbstractBindingHarness$TransformSequencer.transform(AbstractBindingHarness.java:294)
at com.inductiveautomation.perspective.gateway.model.AbstractBindingHarness$TransformSequencer.run(AbstractBindingHarness.java:307)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make field private java.lang.Object java.lang.ref.Reference.referent accessible: module java.base does not "opens java.lang.ref" to unnamed module @409e8a74409e8a74
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(Unknown Source)
at java.base/java.lang.reflect.Field.checkCanSetAccessible(Unknown Source)
at java.base/java.lang.reflect.Field.setAccessible(Unknown Source)
at com.inductiveautomation.ignition.common.gson.internal.reflect.ReflectionHelper.makeAccessible(ReflectionHelper.java:35)
Regards,
There's no safe, general purpose way to GSON serialize an AlarmEvent object. They're PropertySets, which by their nature can contain arbitrary objects of any Java type, which cannot necessarily be serialized.
The most correct thing to do is to rearchitect whatever you're doing to not rely on sending true alarm events between disparate systems.
If you have to use JSON (and have to serialize entire alarm events), then you can get something "working"[1] by wrapping the output of getProperties() on the PyAlarmEvent and passing that to jsonEncode:
print system.util.jsonEncode(list(results[0].properties), 4)
But in the platform, we're not using JSON to encode these objects, we're using Protobuf, which is a completely different serialization format than JSON. In gateway scope, you could theoretically take advantage of that, there's a static getter for the GAN protobuf registry:
from com.inductiveautomation.metro.api import MetroProtobufRegistry
registry = MetroProtobufRegistry.get()
But again - the entire endeavour feels misguided. What is the information you need out of the alarm event on the other side, and can you extract and send just that? Or can you rely on built-in platform mechanisms like remote alarm profiles, so that we are in charge of the serialization problem, not you?
Long JSON
        "advanced": false,
        "bindable": true,
        "category": {
            "defaultVal": "State",
            "key": "enums.CommonAlarmProperties.Categories.State",
            "params": []
        "categoryKey": "State",
        "defaultValue": false,
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.isInitialEvent.Desc?",
            "key": "enums.CommonAlarmProperties.isInitialEvent.Desc",
            "params": []
        "displayName": {
            "defaultVal": "¿enums.CommonAlarmProperties.isInitialEvent?",
            "key": "enums.CommonAlarmProperties.isInitialEvent",
            "params": []
        "name": "isInitialEvent",
        "type": "class java.lang.Boolean"
        "advanced": false,
        "bindable": false,
        "category": {
            "defaultVal": "Main",
            "key": "enums.CommonAlarmProperties.Categories.Main",
            "params": []
        "categoryKey": "Main",
        "defaultValue": "",
        "description": {
            "defaultVal": "Documentation about the alarm.",
            "key": "enums.CommonAlarmProperties.notes.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Notes",
            "key": "enums.CommonAlarmProperties.notes",
            "params": []
        "name": "notes",
        "type": "class java.lang.String"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": "",
        "description": {
            "defaultVal": "The path of the item holding the alarm, not including the alarm name.",
            "key": "enums.CommonAlarmProperties.itemPath.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Item Path",
            "key": "enums.CommonAlarmProperties.itemPath",
            "params": []
        "name": "itemPath",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": "",
        "description": {
            "defaultVal": "The elapsed time between the alarm becoming active and being cleared, as a formatted string. Calculated against the current time if the alarm is still active.",
            "key": "enums.CommonAlarmProperties.activeDuration.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Active Duration",
            "key": "enums.CommonAlarmProperties.activeDuration",
            "params": []
        "name": "activeDuration",
        "advanced": false,
        "bindable": true,
        "category": {
            "defaultVal": "Deadbands and Time Delays",
            "key": "enums.CommonAlarmProperties.Categories.Deadbands",
            "params": []
        "categoryKey": "Deadbands",
        "defaultValue": 0.0,
        "description": {
            "defaultVal": "The time, in seconds, before the alarm will be considered truly active after the active condition becomes true. Also known as a \"rising edge time deadband\".",
            "key": "enums.CommonAlarmProperties.timeOnDelaySeconds.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Active delay (seconds)",
            "key": "enums.CommonAlarmProperties.timeOnDelaySeconds",
            "params": []
        "name": "timeOnDelaySeconds",
        "type": "class java.lang.Double"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": true,
        "description": {
            "defaultVal": "Whether or not this alarm can be shelved.",
            "key": "enums.CommonAlarmProperties.shelvingAllowed.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Shelving Allowed",
            "key": "enums.CommonAlarmProperties.shelvingAllowed",
            "params": []
        "name": "shelvingAllowed",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.isActive.Desc?",
            "key": "enums.CommonAlarmProperties.isActive.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Active?",
            "key": "enums.CommonAlarmProperties.isActive",
            "params": []
        "name": "isActive",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": null,
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.eventTime.Desc?",
            "key": "enums.CommonAlarmProperties.eventTime.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Event Time",
            "key": "enums.CommonAlarmProperties.eventTime",
            "params": []
        "name": "eventTime",
        "type": "class java.util.Date"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.source.Desc?",
            "key": "enums.CommonAlarmProperties.source.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Source Path",
            "key": "enums.CommonAlarmProperties.source",
            "params": []
        "name": "source",
        "type": "class com.inductiveautomation.ignition.common.QualifiedPath"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": "",
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.ackUserName.Desc?",
            "key": "enums.CommonAlarmProperties.ackUserName.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Ack'ed By (Name)",
            "key": "enums.CommonAlarmProperties.ackUserName",
            "params": []
        "name": "ackUserName",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "Specifies whether or not this alarm is evaluated by the system.",
            "key": "enums.CommonAlarmProperties.enabled.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Enabled",
            "key": "enums.CommonAlarmProperties.enabled",
            "params": []
        "name": "enabled",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.isAcked.Desc?",
            "key": "enums.CommonAlarmProperties.isAcked.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Acked?",
            "key": "enums.CommonAlarmProperties.isAcked",
            "params": []
        "name": "isAcked",
        "advanced": false,
        "bindable": false,
        "category": {
            "defaultVal": "Alarm Mode Settings",
            "key": "enums.AlarmModeProperties.Category",
            "params": []
        "defaultValue": {"properties": [{
            "advanced": false,
            "bindable": true,
            "category": {
                "params": []
            "categoryKey": "enums.AlarmModeProperties.Category",
            "defaultVal": 0.0,
            "descKey": "AlarmModeProperties.single.setpointA.Desc",
            "description": {
                "defaultVal": "The value used to initiate an alarm.",
                "key": "AlarmModeProperties.single.setpointA.Desc",
                "params": []
            "displayKey": "AlarmModeProperties.single.setpointA",
            "displayName": {
                "defaultVal": "Setpoint",
                "key": "AlarmModeProperties.single.setpointA",
                "params": []
            "name": "setpointA",
        "description": null,
        "displayName": {
            "defaultVal": "Mode",
            "key": "AlarmModeProperties.mode",
            "params": []
        "name": "mode",
        "type": "class com.inductiveautomation.ignition.common.alarming.config.AlarmMode"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.ackTime.Desc?",
            "key": "enums.CommonAlarmProperties.ackTime.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Ack Time",
            "key": "enums.CommonAlarmProperties.ackTime",
            "params": []
        "name": "ackTime",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.ackUser.Desc?",
            "key": "enums.CommonAlarmProperties.ackUser.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Ack'ed By",
            "key": "enums.CommonAlarmProperties.ackUser",
            "params": []
        "name": "ackUser",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.clearTime.Desc?",
            "key": "enums.CommonAlarmProperties.clearTime.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Clear Time",
            "key": "enums.CommonAlarmProperties.clearTime",
            "params": []
        "name": "clearTime",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "A numeric deadband for the alarm condition. The interpretation of this value depends on the deadband mode. Note that this deadband is separate from, and evaluated after, the tag's deadband.",
            "key": "enums.CommonAlarmProperties.deadband.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Deadband",
            "key": "enums.CommonAlarmProperties.deadband",
            "params": []
        "name": "deadband",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "The time, in seconds, before the alarm will be considered truly clear after the clear condition becomes true. Also known as a \"falling edge time deadband\".",
            "key": "enums.CommonAlarmProperties.timeOffDelaySeconds.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Clear delay (seconds)",
            "key": "enums.CommonAlarmProperties.timeOffDelaySeconds",
            "params": []
        "name": "timeOffDelaySeconds",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.state.Desc?",
            "key": "enums.CommonAlarmProperties.state.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Current State",
            "key": "enums.CommonAlarmProperties.state",
            "params": []
        "name": "state",
        "type": "class com.inductiveautomation.ignition.common.alarming.AlarmState"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "An optional path (separated by \"/\") that will be used for display and browsing purposes.",
            "key": "enums.CommonAlarmProperties.displayPath.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Display Path",
            "key": "enums.CommonAlarmProperties.displayPath",
            "params": []
        "name": "displayPath",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": "",
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.displayPathOrSource.Desc?",
            "key": "enums.CommonAlarmProperties.displayPathOrSource.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Display Path or Source",
            "key": "enums.CommonAlarmProperties.displayPathOrSource",
            "params": []
        "name": "displayPathOrSource",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": "",
        "description": {
            "defaultVal": "The full path of the item holding the alarm, not including the alarm name. An easier to read version of Source Path.",
            "key": "enums.CommonAlarmProperties.fullItemPath.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Full Item Path",
            "key": "enums.CommonAlarmProperties.fullItemPath",
            "params": []
        "name": "fullItemPath",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": "",
        "description": {
            "defaultVal": "The name of the item holding the alarm.",
            "key": "enums.CommonAlarmProperties.itemName.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Item Name",
            "key": "enums.CommonAlarmProperties.itemName",
            "params": []
        "name": "itemName",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "An optional name that will be used for display purposes. Provides a dynamic alternative to the static \"name\" identifier. If left blank, the name will be used.",
            "key": "enums.CommonAlarmProperties.label.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Label",
            "key": "enums.CommonAlarmProperties.label",
            "params": []
        "name": "label",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": {"intValue": 1},
        "description": {
            "defaultVal": "The priority (or \"severity\") of this alarm.",
            "key": "enums.CommonAlarmProperties.priority.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Priority",
            "key": "enums.CommonAlarmProperties.priority",
            "params": []
        "name": "priority",
        "type": "class com.inductiveautomation.ignition.common.alarming.AlarmPriority"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.isJournaled.Desc?",
            "key": "enums.CommonAlarmProperties.isJournaled.Desc",
            "params": []
        "displayName": {
            "defaultVal": "¿enums.CommonAlarmProperties.isJournaled?",
            "key": "enums.CommonAlarmProperties.isJournaled",
            "params": []
        "name": "isJournaled",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "Select this option to require operators to provide some explanation when the alarm is acknowledged.",
            "key": "enums.CommonAlarmProperties.ackNotesReqd.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Ack Notes Required",
            "key": "enums.CommonAlarmProperties.ackNotesReqd",
            "params": []
        "name": "ackNotesReqd",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": {"intValue": 0},
        "description": {
            "defaultVal": "Dictates whether the timestamp used on the alarm comes from the system or the value.",
            "key": "enums.CommonAlarmProperties.timestampSource.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Timestamp Source",
            "key": "enums.CommonAlarmProperties.timestampSource",
            "params": []
        "name": "timestampSource",
        "type": "class com.inductiveautomation.ignition.common.sqltags.model.types.TimestampSource"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": {"intValue": 2},
        "description": {
            "defaultVal": "How acknowledgement works for the alarm: Auto - Alarm is acknowledged when cleared. Manual - Alarm acknowledged by user. Unused - Alarm is always marked as 'acknowledged'. Note that if 'Acknowledged' is a dropout condition in your Alarm Pipeline then you will not get a notification when Ack Mode is set to 'Unused'.",
            "key": "enums.CommonAlarmProperties.ackMode.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Ack Mode",
            "key": "enums.CommonAlarmProperties.ackMode",
            "params": []
        "name": "ackMode",
        "type": "class com.inductiveautomation.ignition.common.sqltags.model.types.AlertAckMode"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.eventValue.Desc?",
            "key": "enums.CommonAlarmProperties.eventValue.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Event Value",
            "key": "enums.CommonAlarmProperties.eventValue",
            "params": []
        "name": "eventValue",
        "type": "interface java.io.Serializable"
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.isShelved.Desc?",
            "key": "enums.CommonAlarmProperties.isShelved.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Is Shelved?",
            "key": "enums.CommonAlarmProperties.isShelved",
            "params": []
        "name": "isShelved",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "defaultValue": "",
        "description": {
            "defaultVal": "The elapsed time between the alarm becoming active and being acknowledged, as a formatted string.",
            "key": "enums.CommonAlarmProperties.ackDuration.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Unacknowledged Duration",
            "key": "enums.CommonAlarmProperties.ackDuration",
            "params": []
        "name": "ackDuration",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.activeTime.Desc?",
            "key": "enums.CommonAlarmProperties.activeTime.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Active Time",
            "key": "enums.CommonAlarmProperties.activeTime",
            "params": []
        "name": "activeTime",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.isClear.Desc?",
            "key": "enums.CommonAlarmProperties.isClear.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Clear?",
            "key": "enums.CommonAlarmProperties.isClear",
            "params": []
        "name": "isClear",
        "advanced": false,
        "bindable": true,
        "category": {
            "params": []
        "description": {
            "defaultVal": "¿enums.CommonAlarmProperties.eventState.Desc?",
            "key": "enums.CommonAlarmProperties.eventState.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Event State",
            "key": "enums.CommonAlarmProperties.eventState",
            "params": []
        "name": "eventState",
        "type": "class com.inductiveautomation.ignition.common.alarming.AlarmStateTransition"
        "advanced": false,
        "bindable": false,
        "category": {
            "params": []
        "description": {
            "defaultVal": "The identifier of the alarm. Combined with the location of the alarm, this will be the unique id of the alarm definition. For dynamic values, use Label and/or Display Path.",
            "key": "enums.CommonAlarmProperties.name.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Name",
            "key": "enums.CommonAlarmProperties.name",
            "params": []
        "name": "name",
        "advanced": false,
        "bindable": false,
        "category": {
            "params": []
        "description": {
            "defaultVal": "Defines how the deadband value is used. If percent, the value (0-100) will be compared against the Eng. limits defined for the value.",
            "key": "enums.CommonAlarmProperties.deadbandMode.Desc",
            "params": []
        "displayName": {
            "defaultVal": "Deadband Mode",
            "key": "enums.CommonAlarmProperties.deadbandMode",
            "params": []
        "name": "deadbandMode",
        "type": "class com.inductiveautomation.ignition.common.sqltags.model.types.DeadbandMode"
  1. this relies on GSON's built in reflection to serialize types without registered adapters, which is ~all of them, so the results are pretty verbose and unpleasant to consume ↩︎
Thanks you for explanations :face_with_monocle: .
In my case, it seems that sending the PyAlarmEvent UUID through the GAN and then a queryStatus request from the remote server successfully did the job.
