Hi All, I have Query related to Kafka connector Licenses. The only way i can see to connect with kafka is using event stream. Is there any other way to connect kafka without using event stream?
Also, i would like to know which license Need to purchase
We do offer some scripting functions that are enabled by the Kafka module, but most users will likely use the module alongside the Event Streams module. You would create the connection in the gateway web ui with the Kafka module installed, details here.
So can i achieve Event stream like functionality with scripting?
