Hi all,
We're developing a module that supports both Ignition 8.1 and 8.3, and I'm testing the supported 8.1 β 8.3 configuration migration path.
On 8.1, the module stores configuration in a PersistentRecord. On 8.3, the equivalent configuration is a named resource using ResourceTypeMeta / NamedResourceHandler.
For migration we're using:
GatewayModuleHook.getRecordMigrationStrategies()NamedRecordMigrationStrategyDefaultRecordEncodingDelegate
The migration itself is working correctly on 8.3.6, including conversion of an 8.1 encoded credential into the 8.3 secret representation.
The part I'm trying to clarify is what the supported lifecycle is for cleaning up the old 8.1 row afterward.
I tested deleting the module-owned legacy row through the public persistence APIs:
GatewayContext.getPersistenceInterface().getSession()
followed by normal find, deleteRecord(), and explicit transaction/commit handling.
That works in testing. I also tested interruption around the cleanup transaction:
- kill before migration
- kill after the new resource exists but before cleanup
- kill after the delete is flushed but before commit
- kill after cleanup commit
The rollback/restart behavior looked safe in those cases.
However, I also found an important restore case: if an 8.3 .gwbk restore is still being processed and the Gateway is killed, the next startup may replay restoration and migration. Because of that, I don't want to assume that simply reaching Gateway RUNNING means it is safe for the module to automatically delete migrated legacy rows.
So I have three questions:
After a
NamedRecordMigrationStrategyhas successfully created the new resource, is it supported for a module to transactionally delete its own migratedPersistentRecordrow using the normal persistence/session APIs?Does Ignition's migration bookkeeping require the migrated rows or
RecordMetadefinitions to remain afterward? -
Is there a public lifecycle callback/event/state that guarantees Gateway restore and record-to-resource migration are fully and durably complete?
In particular, is the Gateway reaching
RUNNINGsufficient, or is there another supported readiness point a module should wait for before performing post-migration cleanup/configuration writes? -
Is there a supported module API for removing an obsolete migrated table entirely?
If not, is the recommended approach simply to delete the old rows and leave the empty table/schema in place?
I specifically want to avoid raw SQL or private/internal database APIs.
Target floor versions are 8.1.33 β 8.3.6, so I'm especially interested in what is supported on 8.3.6 rather than behavior added in later 8.3 releases.
Thanks!
