Hi
I'm using 8.3.6 and it's a trial version but I've set up a historian (DB table historian) under services which is Running but it does not appear in the tag properties under storage provider as I would like to archive data. Am I missing something somewhere?
I've the DB set up and it's valid
Sinéad
The DB Table Historian is read-only. It exists so that data stored in ordinary tables by other means (SQL Bridge module's transaction groups, typically, or scripts) can be displayed in power tables and other components that expect a historian as their data source.
@pturmel Thanks Phil.... I've now set it up as an SQL Historian
