A result set was generated for an update
Ignition 7.9.20 on Windows 12 Server
SQL Server 2019 on another computer.
For 7 years we have had the following working in a python script:
sql = \
INSERT INTO table (col_1, col_2, col_3)
VALUES (?, ?, ?)
system.db.runPrepUpdate(sql, [1, 2, 3])
Yesterday this started throwing errors "A result set was generated for an update...."
The script was changed to:
sql = \
SET NOCOUNT OFF
VALUES (?, ?, ?)
And it now works. Any idea why this failure could happen and why the fix fixes it?
TIA
Mack
I would guess someone on the DB side applied a patch that changed the default for the NOCOUNT setting.
They swear not.
There's not much else it can be.
There are many other similar scripts that are not failing....
Recycled connections might be holding onto the original defautls. Try disabling and re-enabling the DB connection. You'll probably see the rest of the scripts start to fail.
Consider adding SET NOCOUNT ON to the DB connection's initialization.
Would that be in the Extra Connection Properties? Is a keyword required before it?
Yes, not sure. I haven't used it with MS SQL Server.
